Re: Need a little clarification on setting valves
Posted by El Toro on June 25, 2013 at 17:53:46 from (108.3.218.181):
In Reply to: Re: Need a little clarification on setting valves posted by paul shuler on June 25, 2013 at 17:33:53:
One full revolution after setting the first 4 valves. No4 piston should be at TDC on the compression stroke. Use a long plastic straw once you feel compression on No1 piston and watch the straw rise as a helper slowly cranks over the engine. Hal
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
