Re: Farmall Super A hydrualics getting hot very hot!
Posted by Tom Fleming on June 26, 2013 at 04:13:17 from (67.20.233.75):
In Reply to: Farmall Super A hydrualics getting hot very hot! posted by chad from michigan on June 25, 2013 at 19:59:19:
2 things. Is there enough hydraulic fluid in the system? Second item, is the bypass valve stuck or sticky? I am not totally familiar with these systems, but in general, on any hydraulic setup, if the bypass valve is set too high or sticking, the system will heat up, and heat up fast.
