Has it been sitting up? If yes it may be the fuel. Having worked with these in years past it is not uncommon for the motor to run a little rough until the carburetor and fuel line are clear. First clean the glass fuel bowl under the tank . . . even if it looks clean. If you do not want to drip fuel on your torque tube remove the fuel line and install it backwards and turn on the fuel to be sure you have a good flow of gasoline through the line. If not blow it out. Drain the carburetor bowl to be sure there is no condensate collecting there. If this does not work you may have to clean the carburetor . . . if you have spark. If you do this trick and it clears up you might have to repeat it a few times until a couple of tanks of fuel have been burned under load. We had to go through this every spring with our 200 back in the 60's. I have to say, if you have an inline fuel filter get rid of it, you do not need it and it will cause fuel flow problems. If your fuel line has a loop or dips below the carburetor then it could make the engine run rough.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
