Re: farmall 350 ID
Posted by D. Slater on June 27, 2013 at 03:52:36 from (184.14.213.122):
In Reply to: farmall 350 ID posted by angie noel on June 26, 2013 at 20:44:44:
16305 = year 1958 if its a 350. S = tractor came with a T/A and internal parts for a IPTO drive. U = the tractor came with higher compression pistons than standard, intended for higher elevation use. Long axles were a option. Standard rim size for a farmall was 38 inch.
Tractor was probably equipped with the non standard wheel and tires for a special use. Maybe what Georgeky mentioned.
