Re: Farmall 450 rear diff fluid
Posted by bermuda ken on June 27, 2013 at 05:50:51 from (50.50.17.146):
In Reply to: Farmall 450 rear diff fluid posted by Cassandra Dejno on June 26, 2013 at 21:44:37:
Factory fill is 80-90W gear lube.
IF you FLUSH the housing and have replaced EVERY oil seal, you can use Hytran oil instead.
You CAN NOT mix Hytran with 80-90W gear lube.
