Re: Farmall 450 rear diff fluid
Posted by Kenneth R Ohnstad on June 27, 2013 at 06:29:22 from (184.158.64.242):
In Reply to: Farmall 450 rear diff fluid posted by Cassandra Dejno on June 26, 2013 at 21:44:37:
I have a 450. Was told to use 80/90.
TA stopped working. Drained 80/90. Filled with diesel. Drove around about 15 minutes while putting in and out of TA. Drained that and left the plugs out for a couple of days. Filled with Hy Tran$$$.
TA worked great.
Good Luck
Kenny
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
