Re: Farmall 450 rear diff fluid
Posted by D. Slater on June 27, 2013 at 07:59:33 from (184.14.213.122):
In Reply to: Farmall 450 rear diff fluid posted by Cassandra Dejno on June 26, 2013 at 21:44:37:
Bottom of the hole at a square head 1/2 inch pipe plug located on the mid left side of the tractor ahead of the clutch pedal. If refilling after draining, check another plug on the same side below the starter to make sure the oil is leveled out. Hy tran oil is recommended now with a t/a.
Original owners manual from around 1956 will say to use SAE-10 or SAE-10W with one quart of T/A transmission lubricant additive to each 4 gallons used.
Manual printed in 1958 can say use SAE-75 gear lubricant or the combination above. Temperatures always above 40 degrees SAE-80 gear oil may be used.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
