Re: farmall super m repair costs
Posted by sflem849 on June 27, 2013 at 15:19:28 from (69.197.84.39):
In Reply to: farmall super m repair costs posted by jack-iowa on June 27, 2013 at 14:40:56:
If you did it at home, cost of parts or maybe less. If done by a shop it would be worth more.
I would rebuild my M long before I bought a new one. The next one is probably junk, too. Especially if it is only a grand.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
