Re: farmall 460 hydraulic pump
Posted by Janicholson on June 27, 2013 at 16:29:27 from (74.60.94.18):
In Reply to: farmall 460 hydraulic pump posted by farmalllh on June 27, 2013 at 14:37:20:
The spring on the pressure relief could be weak. The valve could be stuck in its bore (especially if the fluid gets hot, or the pressure varies dramatically with engine speed. (just Ideas) Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
