Re: farmall 460 hydraulic pump
Posted by pete 23 on June 27, 2013 at 17:06:55 from (74.32.227.210):
In Reply to: farmall 460 hydraulic pump posted by farmalllh on June 27, 2013 at 14:37:20:
That 1250 psi is pretty much what you get. Book says to 1500 but that is a rare bird that gets it. It is the flow that counts more than pressure to determine if it is working properly. A good system will deliver a minimum of 80 percent of free flow at 250 psi below maximum. The relief valve on those is pretty much fool proof unless the spring has been subjected to over heating many times. I have seen light washers added to the spring to get more psi.
