Re: 460 axle clamps
Posted by D. Slater on June 27, 2013 at 17:56:51 from (184.14.213.122):
In Reply to: 460 axle clamps posted by big_red_man on June 27, 2013 at 17:39:16:
At least a 4 foot cheater on a good wrench or heavy ratchet and socket is needed some times. Heavy duty impact works also. If you have a powerful enough impact the rim can be removed from the wheel and a extension used on the impact to get the bolts on the recessed side of the wheel. Go down through the slot in the cast wheel. You must have the big axles with 7/8 clamp bolts. Most times they will take a lot of pressure without breaking, but they will and make things harder. Use penetrant and if needed heat if you think they are going to break.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
