Farmall Tractors Discussion Board
Re: FARMALL CUB 1953
Posted by Jim Becker on January 17, 1999 at 18:33:01:
In Reply to: FARMALL CUB 1953 posted by GILES on January 17, 1999 at 13:33:39:
Most certainly a blockage in the fuel feed. It could be anywhere. Check any and all of: the tap from the fuel tank, the strainer, line, screen at the carb inlet, float valve and internal passages of the carb.
Start by pulling the carb drain plug. If fuel flows, and continues to flow at a good rate, the problem is internal to the carb. If not, work your way back by disconnecting the fuel line etc.
Post a Followup
: Re: Re: FARMALL CUB 1953
