Re: farmall c transmission
Posted by Dennis K (WA) on June 28, 2013 at 19:10:07 from (24.21.78.195):
In Reply to: farmall c transmission posted by whigg on June 28, 2013 at 13:43:46:
Back to your original question. To see anything, you need to pull the top deck. First get the seat and seat box out of your way. The light bar, touch controls and dash box need to be removed. There are bolts under the dash box holding the deck down. Remove the deck bolts and raise it straight up, its fairly heavy so a hoist or engine lift should be used. You will then be able to see whats inside.
If a shaft needs to be removed you will have to split the tractor between the torque tube and transmission.
Parts coverage available at 'caseih' web site
good luck
Dennis
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
