You hydraulic system is staying on demand. In other words under pressure. First thing is look at the ends of your hydraulic valves. There is a flat on a stem to turn valve from double action to single action. Often times the roll pin gets broken or bent allowing stem to be turned too far. If all valves check ok, then you have a problem in the regulator valve block. It is the valve with four bolts on cover. Under cover is heavy spring so caution if you take it off. I use longer bolts in two corners. You will find a screwdriver slotted orfice with screen. It is probably plugged. You will need new gasket though if you take cover off nine times out of ten.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
