Posted by Tip 'n NJ on June 29, 2013 at 20:13:29 from (71.53.3.135):
Gents:
I have been working through a bunch of issues on my Farmall 656 D.
Rebuilt the shift mechanism. What a difference! I can find all 6 gears easily. I ended up replacing some pins, and welding up a couple of linkages, but mostly just cleaned and lubed everything.
I also installed a new fuel gauge cluster. I have everything working but the oil pressure. My oil pressure gauge is set up as follows:
On the left side of the engine, near the breather is a small rubber hose tapped into the side of the block. It runs back to a sub panel, located on the left side of the "dash", in front of the shift linkages for the tranny. This sub panel is normally hidden by the shift linkage cover.
There are two steam gauges - a water temp and oil pressure gauge. Both gauges have been drilled to allow a high temp "stop" that is wired (to ground) and actuates the warning lights.
The water temp probe in my original gauge was cut off. There is no "water temp" idiot light and of course, the wire on the lower steam gauge was cut off and goes nowhere.
The oil pressure gauge isn't working - which of course makes me nervous, but the tractor has been running great for a long time.
Is this subpanel normal or some weird modification? Doesn't show up in my parts manual. I was looking for an oil pressure sending unit, but it doesn't exist on my tractor. I am going to pull the sub panel tomorrow and see if I can run down the oil pressure gauge issue and then figure out how to make it work correctly. I prefer real gauges, but it would be nice to know that the idiot light works just in case.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
