Re: flat belts for stationary implements
Posted by georgeky on June 30, 2013 at 09:36:38 from (184.43.25.236):
In Reply to: Re: flat belts for stationary implements posted by Haas on June 30, 2013 at 09:20:07:
We run an old Meadows grist mill and a Bearcat hammer mill with flat belts. we use old hay roller belts. work perfectly good for both machines.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
