Re: 574 running rough
Posted by Mike Van on July 01, 2013 at 03:30:45 from (24.151.25.186):
In Reply to: 574 running rough posted by Kirk Affeldt on June 30, 2013 at 07:20:17:
Kirk, could be multiple problems here. The gas tanks on these are getting rusty now, scale and rust will collect in the bottom halves, some will plug the screen [under tank] some will get through and plug another screen on the fitting right where it goes into the carb - Some will still get through that one and cause the float in the carb to stick. Ignition system on these gassers is points and condenser, that may need some attention [cap and wires too] On mine, at about 1500 hours, it was running so bad it was tough to get started. Turned out to be the valve lash adjustment, and at 1900 hours now, it's still running fine.
