Posted by mkirsch on July 01, 2013 at 06:58:57 from (64.80.110.75):
In Reply to: W9 with M motor posted by Dave Meisner on June 30, 2013 at 17:56:30:
By the time you're done buying an M engine, souping it up, and adapting it to fit the W-9 chassis, you probably won't be saving a whole lot of money over just rebuilding the W-9 engine.
Your biggest challenge will be hanging the M engine in the W-9's tub at the right height and distance so it will line up with the transmission input shaft and the throwout bearing will disengage the clutch. That's probably going to require some professional fabrication and machine work, which doesn't come cheap.
Then if the M clutch splines are wrong... Custom clutch.
Then if the M flywheel doesn't line up with the starter... Custom flywheel.
Yep, by the time you're done adapting everything it may just be cheaper to go ahead and rebuild the W-9 engine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
