Re: F-20 flywheel installation update
Posted by Phil Tibbetts on July 01, 2013 at 11:17:32 from (208.93.14.38):
In Reply to: Re: F-20 flywheel installation update posted by EM Iowa on July 01, 2013 at 10:28:58:
Use a drill just a little smaller than the width of the key and drill as close together as possible down to the shaft. It may help to put some good penetrating oil in the holes and let it set for a day. Good luck.
