The biggest single problem with the governor is the wear in the weights and pins. When they get worn you loose sensitivity. In other words, the engine pulls down too far before the governor open the carburetor up. Since the price of those parts has gone completely crazy, what I have been doing is drill out the weight and carrier. Then I install a roll pin. You need to have the hole in weight just a little larger so weights work free but pin is tight in carrier. The thrust bearing has to be in good shape and it is a special bearing not an ordinary ball bearing. Then of course, good spring as they do lose their strength. If the link to carb is worn, that will also need repair or replacement.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
