Re: F-20 flywheel installation update
Posted by cleddy on July 01, 2013 at 21:17:26 from (174.74.58.129):
In Reply to: Re: F-20 flywheel installation update posted by Janicholson on July 01, 2013 at 20:53:10:
Thanks for the information. I see your point and being around this equipment all the time this may advoid being in a accident or causing one by being more informed. I would not like any of my repairs to cause an accident. I hope I did not give the wrong impression because all the mechanical failures I've seen over about 50 years or you hear about, it is just amazing that worse stuff doesn't happen.
cleddy
