Re: 350 brake dimensions ?
Posted by Janicholson on July 01, 2013 at 21:19:18 from (74.60.94.18):
In Reply to: 350 brake dimensions ? posted by riverbend on July 01, 2013 at 11:45:54:
Total stack height and total housing should be between .030 and .060" for best operation. The disks wear, the expander surfaces wear, and so does the tractor surface and the housing. New plates will not usually compensate for metal wear, so machining the housing shorter is a usual practice.
