You also need to check and make sure the pin in the end of the shaft that the bearing runs on is free to slide in and out. It runs on a little raised area on the inside of the housing. I had to soak mine in PB for 2 or 3 days to get it out. There is a spring behind it that also needs cleaned up. It is used to take up the slack as the shaft moves back and forth. There is also a small hole in the shaft to let oil into the spring area.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
