Re: Head Gasket IH 1256
Posted by Owen Aaland on July 02, 2013 at 17:17:54 from (216.47.34.15):
In Reply to: Head Gasket IH 1256 posted by jeddie on July 02, 2013 at 11:22:03:
Unless things have changed since the last one I did install it clean and dry. There is sealant around the areas most likely to leak and adding any other sealant will defeat the sealing ability built into the gasket. Providing the engine has been running about the normal horse power setting the head bolts should be fine to reuse unless you see corrosion eaten into them.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
