Posted by rosedale123 on July 02, 2013 at 17:32:42 from (108.224.113.216):
Got the old B414 running good now I have a noise from the clutch ( I think). It has a 2 stage clutch and when the tractor is running and in nuetral it makes a "chatter". When depressed in the first stage it changes nothing. when the second stage is depressed it stops.when I re -engage the the second stage it the noise will start again ( some times) but it I keep depressing and engaging I can get it to stop. Is this the throwout bearing? pilot bearing?
Now here is where I rat myself out. I had the pto cover off and the 3 bolts also hold the in the pto shaft . the shaft came out a little enough to make the oil leak out.I pushed it back in and bolted it back up tight. Did I do something? Is it something I can correct? It did not make the noise before this "event".
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
