Re: Two Questions about a '45 B
Posted by Tom Fleming on July 03, 2013 at 04:01:33 from (67.20.233.75):
In Reply to: Two Questions about a '45 B posted by jkmdg84 on July 01, 2013 at 17:48:28:
I hate to state the obvious, but it can be 1 of 3 things.
If a a magneto system
1.) The body of the ON/OFF switch requires a GOOD ground to the frame.
2.) The switch could be bad.
3.) there is a faulty wire
If a battery ignition system:
1.) The switch is bad
2.) The switch is bad
3.) the switch is bad
PS Edit: if it is a battery ignition system, try starting it with the switch in the OFF position. If it starts, it is not wired correctly, or the switch is bad. :wink:
This post was edited by Tom Fleming at 04:04:03 07/03/13 2 times.
