Re: 15-30 or 22-36?
Posted by rustred on July 03, 2013 at 08:31:48 from (74.214.152.80):
In Reply to: 15-30 or 22-36? posted by Wayne Koos on July 03, 2013 at 07:38:38:
serial # is located on fuel tank support in front of belt pulley. they pretty much jump right out at you and can be seen from a distance, but at times the tags are torn off to.
yes there is a w-40, it has the 6 cyl. engine.
cant give a value without a pic. not enough info.
are they running, seized, parts, or junk? rubber tires or steel? they can be from scrap price to the sky.
