Posted by soundguy on July 03, 2013 at 08:43:00 from (184.240.25.202):
In Reply to: A poser posted by Phil Tibbetts on July 03, 2013 at 08:23:09:
ditto what bob said.
your mission is nigh impossible.
you can run a 12v 1 wire alt and 12v battery. and run a 6v points based ignition with use of the oe coil and a ballast resistor OR.. simply switch to a 12v coil.. if it uses a common round coil.. a napa ic14sb will work.
that leaves lamps and cigar lighters. lamps.. most old style lamp sizes have a 12v counterpart. if not. wire the 6v lamps in series. not desireable.. but works.
for the cigar lighter.. 2 options. run it like it is and just be carefull to not leave it engaged too long.. or get a ceramic resistor of about 1 ohms and stick inline.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
