Re: A poser
Posted by mkirsch on July 03, 2013 at 09:32:48 from (64.80.110.74):
In Reply to: A poser posted by Phil Tibbetts on July 03, 2013 at 08:23:09:
x4 on what Bob said.
Resistor only works on the coil because the coil is a small constant load.
If you put each separate item on its own resistor, then you could make it work. On a letter series IH, the only other thing on 6V is the lights. Bulbs are much cheaper, easier to replace, and do not add extra complications into the system.
The only way to make it work with one device is with a very large and expensive voltage regulator, and if it fails you are dead in the water wherever you sit. Changing bulbs is still simpler and cheaper, not to mention more reliable.
