Re: Farmall C Front Weight Bracket?
Posted by Dean Olson on July 03, 2013 at 10:52:01 from (166.137.156.153):
In Reply to: Farmall C Front Weight Bracket? posted by BigBob706 on July 03, 2013 at 06:58:34:
It is easy enough to bolt bar stock to each side of the front bolster. There's 3 bolts available. Then weld more bar stock to hang suit case weights either on each side or in front.
You only need about 80 lbs. That seems to be enough to keep the front end down on my SC when I've got fast hitch plow or disc on.
