Posted by mkirsch on July 03, 2013 at 13:15:05 from (64.80.110.74):
In Reply to: A poser posted by Wm. Ecccles - Jardine on July 03, 2013 at 09:55:26:
A 6V to 12V conversion is not impossible, but the way he wants to do it is:
He wants to keep everything 6V, and install one big resistor to "convert" the 12V from the battery/alternator to 6V for the whole tractor.
Ohm's Law, my friend. It won't work.
He'd need resistors on each individual item, custom sized for the load and current. If the item has a variable current, then the resistor idea won't work at all.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
