HI,you can change the brake band with the cab in place. Remove the fuel tank, seat and seat plate, remove all the hydrolic pipe and all the bolts. Normally, with a helper, you can remove the hitch cover by hand, one in the cab and another in the rear of the tractor.. With a car engine hoist, it work fine. Make sure to lift the cover enough, it have a spring under for the draft control You have to remove the PTO clutch pack, to slide the band out, dont pull or twist. Change the gasket and the 3 teflon ring, maybe Oring also. Bernard le mecano Quebec Canada
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
