Posted by Hugh McKinney on July 04, 2013 at 16:47:15 from (75.104.206.93):
In Reply to: H polarity posted by mmkid on July 04, 2013 at 11:35:06:
If it has an alternator it is negative ground. If it has a generator it can be pos or neg ground. Here"s a handy way to usually determine whether it"s pos or neg ground: Looking at the terminals on your ignition coil, take a look at the low-voltage wire that goes from one of the terminals on the coil, to the distributor. If it leaves from the negative terminal on the coil, it"s a negative ground tractor. If it leaves the positive terminal on the coil, it"s a positive ground tractor. Good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
