Re: 1466 flasher
Posted by Owen Aaland on July 05, 2013 at 15:42:36 from (216.47.33.35):
In Reply to: 1466 flasher posted by ihjerm06 on July 05, 2013 at 15:18:22:
If the lights come on the switch is doing its job. The flasher unit is what interrupts the power to get them yo flash. If you have a factory cab the flasher (little silver can) is near the brake pedals. If there is no cab the flasher is located under the platform by the left brakes.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
