Posted by CNKS on July 05, 2013 at 16:53:00 from (216.144.104.128):
In Reply to: Painting with IH2150? posted by pete_5959 on July 05, 2013 at 15:13:19:
Do what the can says for mixing. It is probably 8 parts paint to 1 part reducer. With hardener it is probably 4:1:1, but I don't use 2150, I prefer PPG urethane, which is better paint, also about twice the cost or more than 2150. For hardener you need supplied air to protect your lungs. The only advantage to hardener is that it cures faster allowing mistakes to be corrected the next day. Hardened or not the paint will look about the same. Coats are about 10-15 minutes apart. 3 should do it. If you are using a HVLP gun, set the air at the spec on the gun or in the instructions. Don't change it as it is designed to give 10 psi at the tip. The pressure is reduced inside the gun, and different brands vary as much as 100% or more at the inlet. Fluid flow and pattern adjustment work best wide open. I use a smaller gun for individual parts and get better coverage and save paint. I wouldn't use clear over the paint. Clear works best in the base-clear system.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
