Re: Farmall H backfires
Posted by Shop teacher 94 on July 05, 2013 at 17:56:16 from (173.85.9.34):
In Reply to: Re: Farmall H backfires posted by notjustair on July 05, 2013 at 16:07:51:
Might be a dumb question...but how do I know when I have the carb adjusted right. I did adjust a little to lean it out...but it still smokes a bit, and back fires when warm.
