Posted by Janicholson on July 05, 2013 at 20:03:42 from (74.60.94.18):
In Reply to: Re: Farmall H backfires posted by Shop teacher 94 on July 05, 2013 at 19:37:54:
That is a magneto not a distributor. It has points and condenser, but they are inside and behind a set of gears. I would rather think it was a slightly different issue than having you get into that unit just now. Bumping around with a loader can dislodge both water and trash in the fuel tank. Open the drain in the bottom of the carb to see if a solid stream of fuel comes out. If not, I would clean fuel system lines and the screen at the carb inlet, and the sediment bowl. The person who discussed issues with timing gears didn't know you had a non live Liftall Belly pump system that is not associated with gear damage. Removing the distributor cap and checking for carbon tracks, cracks, or moisture is a good idea. Let us know what you find. Jim
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
