I have to disagree. You"ll see on the RH hitch prong there"s a welded tube,that was used to pin the mower bar "Lead" adjuster unit when used with the Super C and 200 Fast Hitch.That was the rod and bracket that attached to the RH axle housing,used with the rear cultivator rear axle mounting clamp. To my knowledge the #28 did not have that,since the 300 Utility had no need for that setup,it used a bracket bolted to the RH axle housing with a chain and clevis arrangement. I"ll have to go through my old IH manuals and get out my mower attaching instructions to adapt the C-21 P,C-24-P Fast Hitch mowers to adapt to both the 300/400 Fast Hitch,and the later "Traction Control" Fast Hitch,as used with the 230/350/450 tractors. I"m not sure I can scan that,if I can I"ll try to post on here so one can see just what is involved.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
