Re: f-20 rear wheels
Posted by Janicholson on July 06, 2013 at 08:25:33 from (74.60.94.18):
In Reply to: f-20 rear wheels posted by b.williams on July 06, 2013 at 07:48:10:
If (and only if) the rim and removable parts are in good condition, meaning no rusted places with pits, bent or deformed components, or welded/modified. would I consider them usable.
However!!!! the basic idea of horror should be in consideration of the fact that split rim failure with catastrophe is usually associated with high pressure truck rims (100psi or more) not 15 PSI tractor tires.
If things look good, have them put in just enough air to shape the tire. then with it outside facing a clear area, inflate to 12PSI using a clip on hose and a valve to control it. This reduces danger to Near Zero. Run it at 12 for a while and adjust as needed. Jim
