Re: 1966 IH 656
Posted by rankrank1 on July 06, 2013 at 12:05:42 from (198.228.228.173):
In Reply to: 1966 IH 656 posted by Dachshund on July 06, 2013 at 11:31:23:
Just on what you have stated so far I would be looking for some wiring (possibly bare) hitting the shifter linkage and shorting out in those ranges where it will not run inside the dash. If that is not it then I would be looking at those safety switches too. A meter plus a jumper wire should let you bypass a switch to verify it is or is not the culprit.
