Re: Janicholson I need some help...
Posted by Janicholson on July 06, 2013 at 16:03:45 from (74.60.94.18):
In Reply to: Janicholson I need some help... posted by BigTone on July 06, 2013 at 15:41:38:
4th gear is about 6 MPH or so. 5th gear is the street gear at an amazing 16mph. (do it when feeling alert and sober. Just kidding, I believe throttling back in 5th will be a good solution till you are ready for full throttle. The engines do not spin fast. A strobe tachometer to assess the actual High Idle (wide open no load speed will tell the story) The lever is normally doing nothing for the first 40% of travel, and then it starts to give speed. So the first step is to see if it is at rated RPM (On the Model Tag.) This can also be done with a shaft tach or revolution counter, and a watch or display of time PTO should be at 580 to 600 RPM with no load full throttle.
Diagnosis is the first issue. Jim
