Re: A poser
Posted by mkirsch on July 06, 2013 at 17:16:31 from (67.253.161.186):
In Reply to: A poser posted by Phil Tibbetts on July 03, 2013 at 08:23:09:
The Super M I bought last year has a fairly new 1-wire alternator.
It also has a battery cutoff switch wired into the ground on the battery, and mounted up on the light bar.
The previous owner wired the cutoff in because he was having problems with the battery draining.
