Re: super H stage 1 and 2
Posted by D Slater on July 07, 2013 at 03:58:20 from (184.14.201.139):
In Reply to: super H stage 1 and 2 posted by jamie majors on July 06, 2013 at 20:59:41:
Engines and transmissions the same. Stage 2 got a different center housing casting. That moved a different starter to the left and had mounts for the reservoir on the right. That lead to the battery being moved to under the seat with a seat change and the fuel tank having a slight change. Several operating linkages and brackets were changed along with electric wiring and mounting locations of some electrical parts. Stage 2 has the serial plate mounted with the long part front to rear. Stage 2 along with some stage 1 used a different front bolster. Also forgot to say the stage 2 used a grill with 2 extra holes also. But some stage 1 tractors came with the grill also.
This post was edited by D Slater at 09:50:14 07/07/13.
