Re: low oil pressure
Posted by TractormanNC on July 07, 2013 at 05:49:41 from (108.72.58.200):
In Reply to: low oil pressure posted by Lankford on July 06, 2013 at 17:33:54:
If this is a gas engine of the 123-135-153 family, the first thing I would do is drop the oil pan and check for a warped oil pump cover. Common problem with these engines. Many posts in the archives including some of mine. Cheap fix if that is the problem.
