Re: f-20 rear wheels
Posted by robgIN on July 07, 2013 at 07:22:18 from (76.208.0.206):
In Reply to: f-20 rear wheels posted by b.williams on July 06, 2013 at 07:48:10:
also as you are inflating the tire, just put enough air in it that it starts to push against the lock ring, then go around the ring and tap it in towards the rim, put a couple more pounds in and repeat, once the ends of the lock ring meet it is fully latched in the groove, and you can inflate to whatever you need it to be, usually 12 to 15 psi. I usually run 12-13 psi.
