Re: What it is..?
Posted by John In Iowa on November 24, 2000 at 15:11:37 from (199.108.164.13):
In Reply to: What it is..? posted by PLOWBOY on November 24, 2000 at 08:41:09:
This was done to be able to move the distributor in some applications. They used this motor for use on combines and stationery used. The distributor still drives off the cam shaft in that hole. If you look at some Ms,300s and 400s, you will see the same thing.
John In Iowa
Post A Followup
: Re: Re: What it is..?
