Re: Super A Steering Box Rebuild
Posted by riverbend on July 07, 2013 at 17:27:12 from (74.37.55.188):
In Reply to: Super A Steering Box Rebuild posted by Charles Green on July 07, 2013 at 14:18:34:
I was able to remove a lot of play from the (wide) front end on my '40 H by replacing the bushings in the trunnions.
If the spindle is loose, removing the slack in the gears might not make much difference.
Greg
