F300 hyd tower leaking
Posted by Bkpigs on July 07, 2013 at 18:21:44 from (24.182.229.14):
My farmall 300 has a hyd leak from the tower. I took it apart hoping to find a cracked or pinched o-ring but found nothing but good looking o-rings. The ones in there were purchased from a dealer so the quality isn't an issue. The mounting bolts were tight. Do you have any tips when re-assembling to prevent this? As you know it is a pain in the rear to get to it to fix it again.
