Posted by Lmack on July 07, 2013 at 18:25:53 from (24.131.50.165):
In Reply to: Oil for C posted by Russ from MN on July 07, 2013 at 07:11:11:
The designation of oil weights is somewhat arbitrary but generally indicates the shape of a viscosity curve (honey has a high viscosity and water a lower viscosity) plotted against temperature of the oil. The shape of the 30 WT curve is not that much different from a 20-40 WT curve with the 20-40 oil having slightly lower viscosity at low temperature and slightly higher viscosity at higher temperatures. That might be a better fit for an engine where one would want good lubrication at start and sustained lubrication at higher running temperatures. Otherwise the better quality oil has a lower viscosity at low temperatures . . . so that the 5-whatever WT will be a good quality oil that will not tend to break down under use and abuse as quickly as the other oils.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
