Re: 186 wont move
Posted by pete 23 on July 07, 2013 at 18:48:18 from (74.32.227.210):
In Reply to: 186 wont move posted by tjv on July 06, 2013 at 18:17:58:
You can just cap them off to test. The reason the book shows isolation valves is to protect from excess high pressure. The only way you will get that excess pressure is to have engine wound up and brakes locked so to just see if it will pull a light load you don't need them.
